TwinTurbo.NET: Nissan 300ZX forum - Re: Normally you'd just check for voltage at various
Subject Re: Normally you'd just check for voltage at various
Posted by Da Flash on August 07, 2014 at 3:00 PM
  This message has been viewed 101 times.
In Reply To Normally you'd just check for voltage at various posted by jzack on August 06, 2014 at 09:52 PM
Message I checked the fuse in the big box in the drivers side fuse/relay box in the engine compartment (it was good, check it with my multimeter) and I look for an "abs" fuse in the footwell fusebox (there isn't one labeled "ABS". The box by the battery is unlegible so I'm not sure if there is an "ABS" fuse located there. I'll continue to try to track down the source of my "antilock" light.
